Wiped Cam Lobe
Discussion in 'Technical' started by stephen, Jan 4, 2011.
  1. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    You would need to drill + tap holes for the spider and use a small base circle camshaft
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I assume the whole 'small base circle' thing is needed to keep the lifters low in the shorter lifter bores... Correct?
    Will factory tie bars work?
  3. Clintd
    Clintd Member
    Parlin NJ
    yes and yes
