Where is the resistor for coil?
Discussion in 'General Maverick/Comet' started by Grant, Feb 14, 2005.
  1. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Distribitor 180* out? wrong firing order for the new cam? Just a couple of thoughts.
  2. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    Thanks for clearing that up for me :) .
  3. BIGbully
    BIGbully Maverick Maniac
    Omaha, Ne
    I had a buddy who put his sparkplug wires on backwards, I mean he had the right firing order but put them on clockwise instead of counterclockwise. Just a thought. Simple but easily overlooked.
  4. STEVEN
    STEVEN FAST 336
    JOPLIN MO.
    70 MAVERICK
    Like Russ Said Cam Firing Order Might Be Diff. 351w Firing Order Is Diff. From Early 302, Check Cam Grind For Specs.ALOT OF CAM MAKERS GRIND THEM TO 351W FIRING ORDER
  5. Grant
    Grant Member
    Central IL
    77 Mav
    If the cam is ground for a 351, I'm screwed. I'll call Edelbrock with their part number in the morning. Thanks for all your help. You guys are first class in my book.
    I'll post the outcome when I get it running.
    Grant
  6. STEVEN
    STEVEN FAST 336
    JOPLIN MO.
    70 MAVERICK
    Easy There, 351w Firing Order Is Great , They Say It's Easier On The Bottom End Becouse Of The Order Change, All You Have To Do Is Rewire The Dist. To 351w Firing Order!!
