Wheel interchange
Discussion in 'Parts Interchange' started by JonnyRebel, May 18, 2005.
  1. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    I think if they're 5-lug wheels, yes they should fit, but from what I've heard, mid to late 80's-on 4-lug aren't the same pattern as Maverick 4-lugs.
    Bummer, because I have a set of 85 Mustang GT 10-hole aluminum rims that would look good on my 4-lug Mav until I can convert to 5-lug
  2. tim keck
    sharps chapel,Tn
    The maverick 4-lug is the same as,uh....it hurts...vega.Falcons,early Mustangs and those Mitsubishi type dodge challengers from the early'80's also work.Or look for some Weld wheels off a fox 4-lugger,the other 4 holes fit the mav.
  3. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    1972 Maverick 4 door, 347 stroker, c4
    Will Bronco II wheels fit? I found a nice set of alloys on one at the junk yard.
  4. tim keck
    sharps chapel,Tn
    They should,just check your hub center diameter,that's the biggest problem.If your '72 is all '72 they should work.
  5. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    The Bronco is 4wd with locking front hubs.. will it's wheels still fit the Maverick?
    My '72 was all original down to the spark plug wires (except one plug wire and left rear quarter and paint and tires):rolleyes: so I'm pretty sure its all '72.
    If the hub center diameter on the wheels is bigger than the hubs on the car, will they still work?
  6. Jamie Miles
    Alto, GA
    I've had a few
    Yep..
  7. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    Well, I just took the plunge and bought a set of the Bullitts. It'll be awhile before I can afford the tires and adapters though.
