what cam....will heads clear?
Discussion in 'Technical' started by stmanser, Jun 8, 2005.
  1. stmanser
    Davenport, Iowa
    lol...ok....so now i should stick with my heads and port them? this is so confusing and frustrating.....
    i am sure i have 1.6 rockers.....they are stamped steel...i thought about getting 1.7 rockers....to open the cam a little more....
    i will be getting the rear end done...one day....3.55 trac lok..posi..whatver you call it... so thats not an issue...
  2. 74merc
    74merc computer nerd
    1974 Comet
    Unless you have the money for a real set of heads or trip over a great deal, I would stick with what you have, porting optional. You can gain a good bit by porting, but it will do ok without.
    I wouldn't worry about the 1.7 rockers, stock heads don't really increase flow over .5 lift.
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I was referring to the E7 (late model 5.0) heads b/c you can get them for little or nothing. Rework them while you drive your car, port them, pedestal rockers are more common and cheaper, change the valves if you like. I have seen people give 5.0 heads away due to the affordable aluminum heads available.
    Seth
  4. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I have already talked to CompCams & they are going to do a custom grind cam for about $220 for cam & lifters. It's a hydr. cam not a roller cam. The max lift is .495 but is a duel pattern cam. They said it take a day or two to make. It will also have a 108 lobe sep. But a 2500 stall will be needed.
