Welded in the 2003 Mach I fire wall to maverick
Discussion in 'General Maverick/Comet' started by CornedBeef4.6L, Nov 21, 2009.
  1. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Actually the cobra and mach 1 firewall are different than the v6 or gt(unless part guy lied to me), I believe the bullit editions use the same as the cobra and mach 1 but to be fair i could of used any of them with same degree of success.
    To be honest it was pretty strait forward.
    Sorry no pics. and it did happen......
    Believe it or not, I could care less.....:yup: I'll post pics when I'm ready peer pressure has no effect on me
    I got the idea from a Torino owner.
    http://www.fordmuscle.com/forums/makin-progress/485929-twintorino-1968-torino-gts.html
    So as you can see it can be done.....keep doubting if you want....like I said I could care less. I am building this car for me and me only.
    I need to source a K member I like and some shock towers from a newer mustang or proceed with the Mustang II crossmember which I already have.....but in the name of being different I would prefer to use the newer stuff
    The only deference is it was easier on the mav IMO as I just needed to fold the firewall a half inch each side and trium a few minor spots as the Torino needed to add a little.
    Also I think MOdMov71 Travis is doing the same......
    I also eliminated the wipers. I closed of the cowl vents in the cowl panel so it's smooth now. My cowl ducts were perfect too.....i thought they would be swiss cheese....
  2. Cpt. Bondo
    Cpt. Bondo Member
    Summerville, South Carolina
    (2) '72 Comet GTs, 68 Mustang
    Go look for my post in this thread http://mmb.maverick.to/showthread.php?t=61738 and follow the link. It just might help out.
    -Scott H.
  3. CornedBeef4.6L
    no longer here
    Thanks for the link.....Neat stuff I likethe adjustable struts!!!
    I think using an after market sn95 mustang Kmember would work better as i can use a mustang rack etc.....and have correct geometry from the suspension to the engine.
  4. comrick317
    comrick317 Banned
    Mississauga, Ontario
    1976 Mercury Comet
    My Comet has a Pinto firewell, well sorta.:rolleyes:
  5. CornedBeef4.6L
    no longer here
    Ill send you pics if you send me some of yours!!!!(y):D
  6. CornedBeef4.6L
    no longer here
    no way i CALL BS!!!!:biglaugh:
  7. Dave B
    That's why I asked, thanks!
  8. Bryant
    manowar, i doubt youll answer this because you want to be unique but ill ask anyways.
    is the spacing from the firewall to the centerline of the front wheels the same on the sn cars as our mavericks?
    is the track width the same or can it work with a deep offset wheel?
  9. CornedBeef4.6L
    no longer here
    it's close enough:D
    or I could not pull this off
  10. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    :beerchug: Well if you won't give in to peer pressure how about beer pressure?
  11. Dave B
    No pressure needed, you had me at "Beer"!!
