Weber Carburetor on Six Cylinder - Jetting Question
Discussion in 'General Maverick/Comet' started by gregmaverick, May 5, 2017.
  1. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Those that have installed a Weber DGEV or DGAV carburetor with an adapter on the 200 or 250 six, what size jets did you use?
    Thanks!
  2. 71Mavrk
    71Mavrk Member
    Nevada
    The Webers I used to run are up in the attic and I would have to pull them apart to see what are in them.
    I recall having to buy several jets and experiment. Thankfully, they are pretty simple to swap out. Just be careful removing the C clip on the choke plate. It is easy to lose.
    I learned the hard way that you need to pay attention to jetting. I was getting some pinging under load and hard acceleration. Also, my temps were going up. I thought it was timing but it turned out it was running lean. I ate up some valve guides before figuring this out.
    If I were to do it again, I would put a wideband Q2 sensor in and monitor it for best tune.
    This is a good reference book: http://www.books-by-isbn.com/0-89586/0895863774-Weber-Carburetors-Pat-Braden-0-89586-377-4.html
    Micah
  3. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    There are endless combinations - it would be nice to narrow down the playing field.
