Upper Control Arm/Bushing replacement
Discussion in 'General Maverick/Comet' started by MikeG747, Jan 9, 2007.
  1. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Yes, those are the ones...
  2. T.L.
    T.L. Banned
    Southern Colorado
    By the way, I originally just got new shaft/bushing kits from Checker (much cheaper than C.J. for those), but as it turned out, my old A-arms were too badly worn (the metal was hogged-out where the bushings go), so I ended up returning the kits and got new A-arm assemblies from C.J. I went with the aftermarket ones because I didn't want to spend double for the O.E.M. type, and because I don't think (correct me if I'm wrong) the O.E.M. types are greaseable...
  3. 71gold
    O.E.M. types are greaseable :yup:
    ...frank...:bouncy:
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
  5. Rick Book
    Rick Book Member
    Thailand
    Now, I know you've been steam cleaning that ride getting ready for a BIG ANNOUNCEMENT - and that's a pretty scarey picture - but I think I can One-Up you.
    This is how purdy mine was when I first got it:
    (and good luck on your rebuild)
  6. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    They offer a repair kit for this. It is rubber bushings instead of the metal bushings with o-rings. Never used it. Moog makes em......I would just by new a arms but it's a viable option....
  7. Jamie Miles
    Alto, GA
    I've had a few
    1 up
    You call that dirty... you should see the front suspension on my '73 4 door. Car only had a poorly maintained 316,000 on it. The dirt and grime was litterally over a half inch thick above the ball joints...
  8. 71gold
  9. 71gold
    ...and another thing...just how does the a arm shaft work?
    it is right hand threaded on both ends...and i don't see what makes them squeek. mine were the org. from the factory, they had plenty of grease and still squeeked. :huh:
    all that is there is 2 threaded cups w/grease seals.
    ...frank...:bouncy:
  10. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I just got all my parts today, minus the spring perches, fairly straight forward....hardest part for me was drilling the old upper ball joints out.
  11. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    thats kinda waht I was wondering.
  12. bmcdaniel
    Inside the cups are very course threads and mating threads on the shaft with a film of grease between them. One end is left-handed, the other end right-handed. Once they wear out from metal-to-metal contact no amount of grease will keep them from squeeking.
  13. 71gold
    ..mine were both...right-hand thread...:yup:
    i don't think ...left/right threads... would work...:huh:
    ...frank...:bouncy:
