Autozone used to sell them under the Brute Force name. Summit And Jegs still sell them under Lakewood. If some one is intrested i can get the part # for the STOCK Maverick joint. I dont think they make them in the Big - Little joint. I went on and found the link from Summit.It says this joint is greasable, But the last ones i got were not, And the picture of the joint dont show a grease fitting. The one from jegs says Not Greasable. http://store.summitracing.com/partdetail.asp?autofilter=1&part=LAK%2D23013&N=700+4294908331+115&autoview=sku http://www.jegs.com/i/Lakewood/620/23013/10002/-1 http://www.autozone.com/R,2386287/v...partType,00178/shopping/partProductDetail.htm
All the parts houses sell the non greasable joints. I've even bought this type for the original tiny center joint of my Ranger's 2 pc shaft. Bought it from Advance Auto. With a V8 twisting on it, the extra strength was very noticeable. So much so that it survived a dry burnout on rough asphalt behind the 331/4speed with traction-loc'd 275 tires. The slip joint it was installed in, let go in this case. The joint held up fine.
