turbo mav?
Discussion in 'Technical' started by johnson, Oct 26, 2009.
  1. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    a buddy gave me a turbo to put on my cavalier but i think it would be more interesting on the 250. not too worried about the motor. anyone else do this?
  2. Bryant
    go for it. make sure you understand what you need to do with the fuel system and ignition system. ive see people put turbos on and melt down there motors because they had no method to enrich the fuel under boost.
  3. darren
    We put a turbo on a stock Dodge Shadow at work for the hell of it.(extra parts lying around) It went like stink for a while (non turbo engine internals) then as expected it melted away into a parts car.
  4. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    you can safely run 6 to 8psi on a stock engine as long as compressions isnt over 9:1
    you just need youre tune and fuel supply on par
    i'm in the process on doing this to my 72 skylark with 350
    need blow thrugh carb
    aeromotive 1000 electric fuel pump
    aeromotive a2000 boost regulator
    something like an msd 6bta ignition box and magnetic pickup distributor would be key..
    a snow performance progressive alki kit helps too but not needed
  5. maverick75
    Just wondering, what are the turbo specs?
  6. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Check out the forum at www.classicinlines.com There is a Falcon there with a 250 and turbo running high 10's in the 1/4 mile. (y)
  7. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    anyone know how to decode?
  8. maverick75
    Decode what?: engine, car vin, turbo?
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    You need a decoder ring. Once found in Cracker Jacks, now in breakfast foods. :rofl2:
  10. 75 Vomet
    75 Vomet Member
    Shickshinny, PA
    75 Comet GT, 03 Ranger, '11 Fusion,'13 Escape S
    You'll shoot your eye out!
  11. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    decode the turbo
  12. darren
    Drink your Ovaltine!!! :)
  13. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    google the tag on the turbo..somehting like a t04e? or something similar?
  14. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    bump!
    so did you look at the tag on the cold side of the turbo..it lists most of the specs
  15. 2mav4u
    Tolleson Az
    when i took my maverick to speedworld (local drag strip) the shop guys told me to boost my car but i have a 200ci so i told them no. i saw their boosted maverick (250ci) also running 10s that same day
