Tubbed Maverick Pickup
Discussion in 'General Maverick/Comet' started by actionrpm, Nov 12, 2007.
  1. mav1970
    Lookin' Good, Jack:thumbs2:
  2. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    Heres an update on the Maverick project,the rear is narrowed,and the 4 link and diagnoal are installed,with the coilovers,The axles came in Fri. and I built a Detroit Locked 4.88 Pig for it,I fit the tubs all in it and they will be reinstalled and welded in Mon.Last week I finished the cage door bars and fit the seat,should have all the tin work done this week.Then we will move onto the Must.II front,I"ll try to do good pic.s and a lot of measurements to follow along with on the front for you guys thinking of doing it yourself.Jack
  3. Mavaholic
    Cool stuff!!! Going to have it ready for Carlisle?
  4. ericglo
    ericglo Member
    n/e illinios
    1972 maverick
    I like that jig you have there. Looks like an old stock car jig?
  5. mav1970
    I bet it is too. :yup:
  6. stangclone
    stangclone Member
    ofallon,il
    1972 maverick,1965 mustang
    actionrpm it looks like you welded the cross member to the stock frame rails instead of going to the rockers is this way stronger? I did see that you cut them off at the cross member and plate them just wanting to know if this is a better way. nice job it looks really good and I to like the paint job.
  7. actionrpm
    western pa.
    My customer wants to race it this summer,the motors done and I should have the Must II and motor mounts in within a couple weeks,I"ll see if he'd want to bring it out there,it's only about 4 hr.s or so,from here.Jack
  8. actionrpm
    western pa.
    Actually it's Blackhawk Frame bench from the mid '80s,you would rent fixtures from Blackhawk for each specific make and model when repairing frame damage,or replacing rails,and there were also universal fixtures,thats what I use,notice it says Ford Rotunda...If it was in a Chevy dealer it would say Delco.Works great for what I use it for,Thanks Jack
  9. wagesofsin
    wagesofsin Official Lurkologist
    sarasota, florida
    74 challenger , 73 'cuda , 72 challenger , 74 barracuda
    nice work jack.
    :thumbs2:
  10. actionrpm
    western pa.
    Somewere way back in this thread I noted that I like to leave the stock rails in until cage and everything was welded in to keep the body from moving around,although on the bench it stays in place really good,I plated the inside of the rail first then welded X-member to it ,Every job is a little different,but after just putting ladded bar coilover under my Mav.right before I started this one,I noticed the spring perch area is double and triple layers of heavy metal,good place to tie all of it in that way,the inner rocker a lot of time is just sheetmetal,so you just kinda find the strongest way to do it on each different vehicle.Thanks Jack
  11. mav1970
    Carlisle is only a 2 hour drive for me. Would love to see the truck and also meet up with you.
  12. rayzorsharp
    Lookin awesome!!!
  13. Mavaholic
    Hope it makes it!!!
  14. actionrpm
    western pa.
    I finished the tub part of this project today,tubs and floor are done,aligned everything for a final time,brakes are all finished,I like to use the 11" '73-'79 F-150 rear brakes,they are cheap,big,and they really stop good,then I just redrill the drums to whatever pattern I'm using .Put all my tabs on for brake hose and org.Mav.E-brake cables,filled rear with lube and put tires on for the last time(customer bringing correct lug nuts)Time to move to the front and start the Must II conversion..Thanks for following along,Jack
  15. rayzorsharp
    Damn...that's lookin friggin awesome!!!:clap:
