tub and narrow?
Discussion in 'Technical' started by afjaybird, Apr 17, 2006.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Yes
    Set yourself up with a fuel cell with a sending unit in it.
    Other choices will improve streetabilty, such as suspension design, shock type, heim joint construction type, and size and type of tires.
  2. afjaybird
    afjaybird Member
    vandenberg afb
    70 maverick grabber
    ok i was looking at fuel cells and is it ok to put subs and an amp around those and also is there a way to route the normal tub to the fuel cell or will i have to pop the trunk every time i fill up?
  3. afjaybird
    afjaybird Member
    vandenberg afb
    70 maverick grabber
    well i guess if im doing this cant really be a sleeper
  4. don graham
    without going to a whole lot of work your going to have to open the trunk each time you get gas. jmo
  5. Jamie Miles
    Alto, GA
    I've had a few
    Yep, always had to open the trunk to put gas in our Comet. Not really that big of a deal. Just gotta be careful not to drip any in the trunk, 'cuz it will stink the whole interior of the car up if you do. That is, if you consider gas stinky. :)
  6. mavman
    mavman Member
    Arkansas
    If you have a backhalfed "street" car and any sort of motor in it...you won't need those subs and amps. The motor will make all the music you want.
  7. sierra grabber
    sierra grabber Certifiable
    northern nevada
    i presume youll be taking out the back seat for this mod? if so, just mount your amps and speakers there.like jamie said, be careful fueling but a couple drops wont kill you. my highboy has the in cab tank and sometimes on a hot day it will get stinky in the cab. just roll the window down and go faster:evilsmile
  8. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
  9. afjaybird
    afjaybird Member
    vandenberg afb
    70 maverick grabber
    well i thought i had to take out the back seat so yeah i will take it out dont want the dogs in there and dont have kids yet so then i will just have to choose between the wife or a friend.....i'm thinking
    oh andi wasnt worried about gas in the trunk im worried cause on base you cant fill up containers in your car so im wondering about that i will have to explain myself every time i fill up
  10. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I've seen cars with tubs and fuel cells that used the stock filler location, don't see why it wouldn't work on a Maverick. The fuel cell would have to mount low between the frame rails, sort of like a NASCAR car....
  11. Old Guy
    Old Guy Member
    Yes, the cell will hang well down towards the ground to use the original fill tube. Back halfing the Mav with four link or ladder bars and tubs, is not a quick and easy job. Just talking from experience, will take a minimum of two weeks, depending on time put in each day or night, to get it perfect(cutting the floor up to the door jam's, and lot's of precise measuring before welding in the new rails etc.) and where the car will track staight and not get wild on full accelleration. Then there is the question of roll cage to tie the whole thing together for strength and such. Are you going to use one of these set-up's? I may be misunderstanding your exact intention's. Leaf springs are no more unless you plan to move them inward somehow. Large, wide tires need lot's of wheel backspacing to keep them tucked in the fender well's, leaf's will be in the way if you don't move them in. Mini tubbing it for a 10.5 or 11 in tire might work too, if the leaf's can be moved also, still lot's of work. Coil over shocks will be the best way to go in my opinion. You can try putting one of the smaller cells in the front where the battery used to be(had to move it to the rear), that should really blow their mind's when you raise the hood to fill-er up.
  12. afjaybird
    afjaybird Member
    vandenberg afb
    70 maverick grabber
    i cant wait till i left the wife go and get gas with it and some guy who thinks he knows alot stops her lol
  13. afjaybird
    afjaybird Member
    vandenberg afb
    70 maverick grabber
    just wanted to see my new sign
  14. afjaybird
    afjaybird Member
    vandenberg afb
    70 maverick grabber
    ok someone asked about my dads shop so i finally talked to him and his shop is called complete auto off of manchester and ask for tim for drag racing stuff he said hes the main guy in the shop for it (mention me jason and he might do stuff as a side job for cheaper?) but he is suppose to own the shop when the main guy retires he already runs it so there is all the information on my dads shop if you want anything else just tell me
  15. maverick1970
    Missouri
    I am familiar with were that is at, South side of Manchester just West of Baxter Road in Ballwin.
