torino clutch pedal setup
Discussion in 'Technical' started by jean282, Nov 7, 2005.
  1. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    i can buy all the stuff to convert auto to manual from a 72 torino whit a 302 and a toploader. Anyone have try to use the clutch pedal setup on a comet?
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The Torino toploader is not a bolt in like a Stang toploader.
    The Torino is longer, therefore it uses a long tail tranny, and the shifter is set further back.
    The long tail toploader is to manual trannys what the C6 is to auto trannys. Size-wise anyway. It is the same length as the C6 and uses the C6 crossmember, mount, and yoke.
    If you are familiar with what it would take to swap a Mav to a C6, then you know about what it would take to use this tranny:
    Custom crossmember
    Custom driveshaft
    Those are the biggies anyway.
    Good luck
    Dave
  3. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    them if i use a short tail shaft they will be like a stang tranny?
  4. ratio411
    ratio411 Member
    Pensacola
    All Stangs used the short tail toploader.
    It is a direct bolt in for a Mav, and uses C4 dimensions. So it is a simple swap into any Mav, be it 3 speed or C4.
    The only fun part is the pedals and linkage if doing an auto to manual swap.
    I don't know about the Torino pedals. I used Falcon pedals and ended up doing a lot of fabbing and hybriding the parts. My gut feeling is that the Torino stuff will not work.
    Good luck
    Dave
    Edit: Did I misunderstand your question?
    Sounds like you may have been wondering if you could just change the tail shaft housing on your Torino toploader and make it a short shaft.
    Short answer: No.
    Long answer: The Torino tranny is the same as a Stang tranny for the most part. You could swap enough parts to make a short shaft tranny, but it wouldn't be cost effective IMO. It calls for some major (expensive) parts replacement and a complete teardown of the tranny to swap. Cheaper to find the right tranny.
