tore my new engine apart today
Discussion in 'Technical' started by newtoford, Mar 30, 2008.
  1. Dave B
    Yes, Fel Pro gaskets, a little bit more money than some, but well worth it.
  2. newtoford
    newtoford Member
    New Castle Delaware
    the felpro set is $65 thru summit. still a little cheaper ompared to others listed on the page
    some of the local "old farts" are kinda scared these pistons and/or heads are seriously going to hold me back
    any ideas? like i said im not looking for much but they think they'll negate any affect a mild cam or intake combo might do
  3. Dave B
    There are different Felpro sets, with different grade cylinder head gaskets. I don't see any problem using those pistons, your not building a race car.
  4. newtoford
    newtoford Member
    New Castle Delaware
    OK, thats what i was thinking
    any thoughts for head gasket thickness?
    if i decrease the head gasket thinkness i'd then have to get inake gaskets tat were that much thinker and push rods that were that much shorter?
  5. Dave B
    Just use the a stock replacement set, for that year engine.
  6. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    so whats your plan for it? any heads? im a C9 (69) Windsor head kinda guy;), still iron, but will make more power than every other factory head...bet on it
    keep us posted(y)
  7. Dave B
    Or a nice cheap set of E7TE's that someones worked over..
  8. newtoford
    newtoford Member
    New Castle Delaware
    yea. car cruise season is kicking off this weekend so i'll se what people have sitting around they wont be needing lol. junk yards are a lost cause around here.
    when you mentioned the head gaskets i thought you were saying get thinner ones to bump the CR
    the fel pro set in summit is the same set for all 68-82 302's
  9. eddie1975
    Martinsburg, WV
    sold
    E7s:16suspect
    im going to prove everyone wrong(y) C9s kick arse
    if i had the dough id take two engines with similar parts , one with c9 and one with e7s and see what comes out on top
    niether head was great from the factory
    c9 werent great from the factory stupid exhaust bump
    but rated at 290hp
    E7s? not sure on hp numbers but c9 out flow e7s with simlar port work
  10. Dave B
    He should be able to find a set of better heads than he has, already ported & polished with a recent valve job for cheap. The cylinder head discussion is like :deadhorse
  11. eddie1975
    Martinsburg, WV
    sold
    yeah your right, any head is better than the old 77 pieces(y)unless your building a boat and need some anchors:yup:
  12. newtoford
    newtoford Member
    New Castle Delaware
    i definatly find that statement believable
    my friends grandfather offered me a 71 torino 4v 302 for free last summer and i didnt take it. its been outside under an old tarp for about 12 years now so i was a little nervous lol maybe i should go see if the offer is still open
  13. baddad457
    If you really want to bump the compression up, use a set of C6OE 289 heads. You'll loose about 14-15ccs in chamber volume. Your compression will go up from about 8.5 to 9 to 1, to 10 to 1. If you do some hunting, you could find a set of these that have been reworked with bigger valves and porting, along with screw in studs and better springs, all for less than you'll spend on anything else.
  14. newtoford
    newtoford Member
    New Castle Delaware
    so i whiped out the wire brushe for my drill and cleaned 'er up
    just sat everything on for the photo op
  15. baddad457
    Looooooooooking goooooooooooood !!!!!!!!!!!!!!!!!(y)(the short block any way);):D
