Took a little drive today....
Discussion in 'General Maverick/Comet' started by Craig Selvey, Apr 16, 2007.
  1. riporter
    riporter Member
    Charleston S.C.
    Sorry bud, but someone had to do it.
    :ttiwwp:
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    congrats Craig, I am sure it was a great feeling to cruise around in it!!!
  3. scooper77515
    Post a video of a REVERSE BURNOUT!!!:thumbs2:
  4. Craig Selvey
    No stripes yet. Heck....no fenders, hood, or front bumper either!!
    Overly calm the first time it leaked because I used silicone brake fluid. Place that rebuilt it said to NOT use silicone...so I had to flush it all out with denatured alcohol and used Dot 4 this last time. Yes...leaked all over....but I had it all masked off with plastic so I was prepared. I will leave the plastic on until I get this figured out.
    Yes....one really has to tighten all the connections with new stainless steel lines....because they don't seal as well as regular lines if you don't. I had a few leaks there as well.
  5. Craig Selvey
    I had a few of those since the car only starts in reverse. One time it slammed the open door on my leg. Just about drove it thru the garage a couple of times. Decided it was best to move it WAY far away from anything before I start it. :D
  6. Stefan
    Montreal, QC
    Wow Craig!
  7. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Power Disc prop-valves are no different from Manual Disc prop-valves.
    You should demand your money back since they obviously can't rebuild it so that it is reliable, and then hit the junk-yards...
  8. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    1972 Grabber/1972 Sprint/1976 Stallion
    Can't wait to see the finished product Craig! Congrats on being mobile once again. I am sure the brake issues will be over soon. I used the self bleeders on the Grabber last year. 1/4 turn and pump the brakes. Pushes all the air out with out allowing the it to feed back into the system. $9.00 for two bleeders at Pep Boys. I think they call them one man bleeders. Worked like a charm on my old drum system. I plan on using them again when I install the disks later on this year!
    Jerryfow2
  9. Mercurycruizers
    Venetia, PA
    Way to go Craig. It's an awesome feeling being able to take them out on the open road....Can't wait for pics....
  10. Craig Selvey
    They are different in how they mount and where the lines get plumbed in. I could make another one work....but that would require drilling more holes or bending up different lines.
    Having my money back doesn't help get the job done. I really think it was my own fault.
  11. T.L.
    T.L. Banned
    Southern Colorado
    Come to think of it, you're right. The one I had was vertical instead of horizontal, so I never bolted it to the car when I was using it (it was just suspended by the lines). I wouldn't want to drill new holes either...
