Still leaning
Discussion in 'Technical' started by scooper77515, May 7, 2006.
  1. stmanser
    Davenport, Iowa
    is it possible that the leafs are not bent the exact same when they were made.... creating the dificiency?
    just a thought
  2. Blown 5.0
    MS.
    1974 Maverick
    Gas weighs 6.5 pounds per gallon, gas tanks on Mavericks sit to the driver side. Instant lean, unless you move over to the passenger side to drive. I have owned many Mavericks and over half had the lean. I have removed one leaf from the righ side spring which will usually straight it for awhile. The only perment fix is a set of adjustable bars such as CAL-TRAC. You need the bars anyway so why keep fighting a losing battle, get the CAL_TRACS.
  3. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    It looks like...on the 6" side there is more tire tread. Also, I strongly believe that a front alignment is a total waste if the front wheels are not aligned with the rear..Just my:2cents:
  4. rayzorsharp
    I believe your entire leaning problem is in the front. You need a matching set of springs and a good front end, including a good alignment. Until you do that, you might as well forget about your leaning problem.:)
  5. scooper77515
    That is kind of the direction I was "leaning" :p
  6. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Brrrrmp-Clang! :rofl:
  7. scooper77515
    Just got A/C installed in my garage with a light switch that opens up an electric vent opener-thingy...might get a chance to try it out this week or weekend while I work on the lean.
    Let me know if you guys think this is a good plan:
    --Jack up level by frame at rear
    --cut (or shim) front springs until level at the front
    --lower and verify front stays level (maybe drive a little so it settles)
    --shim (if needed) at rear
    --allignment?
    This is kinda the direction I am thinking. If anyone is an "expert" at this, I would love a PM or phone number to run some stuff over with you.
    Gotta get this thing flat in the near future...
