Steering and clutch linkage
Discussion in 'General Maverick/Comet' started by Shadow750, Jun 21, 2023.
  1. Shadow750
    Shadow750 Member
    NC
    If I'm posting this in the wrong place I apologize. The site is a bit confusing to me.
    I'm looking for some help. I have a 1970 Maverick that I ripped out all the 6 cyl stuff and suspension. I'm having trouble figuring out the right rack and pinion kit to use, (power). and I am having trouble finding the clutch Z bar to work with the 302. I need to figure out the rack, header clearance and the stock style clutch linkage. Im using the T5 with Franks crossmember. Thanks Frank. Any help from anybody who has been through all of this would be appreciated. I was going to use the Unisteer rack but come to find out its not that great and has geometry issues.
    Thanks Brian
  2. bmcdaniel
    Back when I first put a V8 in my '70 (1973) the Maverick V8 clutch linkage wasn't available from dealers and there weren't any in local junk yards yet so I used, and am still using, '66 Mustang linkage. All the Mustang supply houses and eBay sells them.
    Russell likes this.
  3. Shadow750
    Shadow750 Member
    NC
    Thanks. Ill try the 66 mustang zbar.
  4. Craig Selvey
    Unisteer is going to be your only choice if you want to keep your factory suspension. Otherwise you could look at a Mustang II type of suspension, take out the shock towers, etc.
    I would consider going with a hydraulic clutch and not use a z-bar.
    mojo likes this.
  5. Shadow750
    Shadow750 Member
    NC
    Craig, thanks for the advice. As of right now Im going with the Borgeson power steering box and using all the stock steering components. Im putting in the Total control coil over suspension and the RRS 3 link torque arm setup. With a 9 inch rear. I was told unisteer as too many issues and big bumpsteer problem. Plus Borgeson is way cheaper. Plan to use a Flaming river tilt column.
  6. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    The Borgeson power steering box was going to be my suggestion. Despite their popularity, rack and pinion conversions often create serious geometry problems in cars which didn't originally come with a rack.
    The stuff from RRS is really nice, and I'm a fan of torque arm suspensions in cars which originally came with leaf springs.
  7. Shadow750
    Shadow750 Member
    NC
    Thanks for the help and suggestions. Borgeson is what I have been told by others as well. It looks like thats what I will be doing. just not sure about the coil over front end kit yet. I like Total Controls kit but big bucks.
    Thanks Brian
  8. Acornridgeman
    Wisconsin
    With the T5, forget the Z-bar or the cable type and go hydraulic.
    I used the Modern Driveline kits and am totally happy with it.
    mojo likes this.
  9. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    This may not be your thing, but I really liked this garage-built coilover setup. It's plenty sturdy and looks like it would work really well. Unfortunately I didn't take notes of where I found it. Good chance it was someone here on this forum, but it could have been from somewhere else. Home built front coilover kit bottom.jpg
    Shorty likes this.
  10. bmcdaniel
  11. Shadow750
    Shadow750 Member
    NC
    very nice thanks
  12. Shadow750
    Shadow750 Member
    NC
    Thanks. I have that setup in my F100. Got it from American Powertrain. Same thing.
    Acornridgeman likes this.
  13. William623
    Orlando
    1973 ford maverick grabber
    That was actually made by a guy local to me. He built the car for drag racing.
  14. Shadow750
    Shadow750 Member
    NC
    Very nice.
  15. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Oh, thanks!
    Btw, I think it could be done with a T-bar on the bottom to get the bottom of the shock probably another 1 1/2" lower. Then the bottom of the spring wouldn't be quite so close to the bottom of the shock. But I'm not sure what the on-center dimension is of the spring saddles.
