Starter help!
Discussion in 'Technical' started by FordCountry180, May 29, 2010.
  1. rthomas771
    6 bolts...not necessory, some converter don't have a drain.
  2. FordCountry180
    FordCountry180 Member
    Parkesburg, PA
    1970 Maverick -302 - -C4 Trans -8" rear
    How can i tell if it is a 50 oz motor or not?
  3. justin has a 74
    kentucky
    Not too sure, is it a roller motor? also some info on the balancer i believe would tell you.
    If you know what the motor is out of and your sticking with the "big" bellhousing, just go to your local parts store and order a flexplate for that motor, tell them to read the discription to make sure.(y)
  4. 71gold
    4 nuts/bolts on the converter...(y)
    remove the battery cable and starter first.
  5. FordCountry180
    Parkesburg, PA
    I just know its a 1980 motor, i wish i had the vehicle info. Would the casting# tell me? I have that written down somewhere. Yeah if I have to take out the tranny i guess it will be easier to find a flexplate then a bellhousing. What would be even better is to find starter to work with this 157 tooth flexplate and big bell housing.
  6. FordCountry180
    Parkesburg, PA
    Thanks, i was checking it out last night. I have lots of stuff to take apart. I think i'll have to loosen the headers on the passengers side to clear the bell where the starter bolts up. Dropped the driveshaft too last night but lost my ambition when i started wonderfitzing <- is that a word?
  7. 71gold
    this ain't going to happen...:sorry:
  8. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    1980 302 would be a 28 ounce balance from the factory, BUT in your first post you stated your engine was BUILT by engine builder. He could have used a zero balance, 28 ounce, or 50 assembly. Well now you should be able to ask your engine builder, or look at your reciept.
    Or you can drop the oil pan and get the numbers off the crank and go from there.
    Cause the crank, balancer, and flywheel/flexplate have to match.
  9. PaulS
    they use the same starter, the big bell just relocates it for the larger gear... sorry.
  10. FordCountry180
    Parkesburg, PA
    Alright looks like I've got to figure out what i've got here because something ain't right, well we already know that Help me out - here is what i currently have -
    1980 Ford 302 casting #E0AE D3C
    Damper 28 oz imbalance Casting# D00-C1-SD D5
    I'll have to look in at the crank# and see what i've got there.
    just talked with engine guy, says i have a 28 oz balance.
  11. FordCountry180
    Parkesburg, PA
    Hard lesson learned here, oh well. :huh:
  12. justin has a 74
    kentucky
    Go out and get yourself a 164 tooth 28 oz flex.
  13. 71gold
    I have one if he goes that route...:thumbs2:
    ...but will his T/C bolt to it?...:huh:
  14. klynam
    klynam Member
    Big D
    1975 Maverick
    Don't know anything about the conversation at hand, but I like your new word :clap:
  15. FordCountry180
    Parkesburg, PA
    My engine guy is going to let me have one(flexplate). I just have to go pick it up. I'm going to try to get the tranny out tomorrow, thanks though! :tiphat:
    I'll keep you posted.
