Speedometer Gear
Discussion in 'Technical' started by Ford Guy, Mar 15, 2007.
  1. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    That is a nice calculator, yellowgrabber, but it only has an option for a C6 automatic. Do you know if the calculations would be the same for a C4 automatic?
  2. baddad457
    I don't see how that guy came up with the notion that C-6's have a removeable drive gear, all the Ford automatics have the gear cut into the output shaft. And he's off on the asssumption that Toploader speedo gears all are cut the same direction, the Galaxie Toploaders have the speedo gear going in the same side as the automatics and the gears for these are like the automaitcs in that regard.
  3. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    I sure would like to know as well.
  4. yellowgrabber
    yellowgrabber Member
    Camano Island, WA
    72 Maverick Grabber, 61 Falcon Futura V8 363ci Dart Block, 62 Falcon V8 289ci toploader
    I've been looking... I had another one bookmarked on my PC at home but I'm on a business trip right now. I believe it had C4 and common overdrive transmissions.
    I'll keep looking, but I have to believe the calculations (i.e., # of teeth for the transmission and speedo cable gears for specific tire height & gear ratio) will be the same.
    I know for sure that Toploader manual has a removable colored gear but I think we have concluded that the Automatics do not have a removeable main shaft/tail shaft gear so you would really be stuck with selecting the closest gear that goes on the speedo cable... like with the C6. Make sense?
  5. das351965
    das351965 Member
    sc
    2-71 mav 1-71 grabber and 75 4dr parts car
