Slotted wheels ...
Discussion in 'General Maverick/Comet' started by dmhines, Jul 17, 2004.
  1. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    Oops, if I'd been paying attention I guess I probably would've noticed you already said which discs you put on. :slap: My bad.
  2. bigal3000
    bigal3000 Member
    Vancouver, Washington
    1973 Grabber
    Hey, I even forgot what I said already. :D
  3. Craig Selvey
    I seem to recall that the hole in the middle of these alum wheels is too small to fit over the rotor.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Keep in mind that both Mustangs and Mavericks were available with these wheels. However, they are not interchangeable. Actual Maverick wheels have the larger holes so they fit over the front and rear hubs which are larger than Mustangs. Mustang have the smaller hole and will not fit on a Maverick ... as Craig stated above ...
    Here are the Mustangs rims that will not fit a Maverick .. They look identical but they aren't ...
  5. MapleMav
    MapleMav Member
    '72 Sprint
    I thought I had seen a thread on this board somewhere about getting the slotted wheels to fit on the Granada/Mav disc setup, saying that you just need to have the "snout" of the rotor turned to a smaller diameter so the wheels will fit. Can anyone confirm this?
  6. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I hope that they fit. I bought Stephen Moore's rotors and calipers off of his
    '74 Comet GT that had factory slots. I have to get the spindles to do my
    swap, but I am running the factory original slots on my GT right now with
    the dumb, I mean drum brakes.
    Seth
  7. dmhines
    Cumming, GA
    Trust me ... if you have the correct Maverick spindles, rotors and calipers and actual Maverick Slots ... there is no problem .... Excuse the body shop dust but here are some pics ...
    Stock Maverick Disc Brake setup in first picture ...
    and
    Factory Maverick aluminum slot ... mounted and spins freely with no clearance issues ..
    If you are having rim to caliper clearance issues something is not an original Maverick part ...
    By the way ... the rear of the slotted wheel looks dimensionally identical to the standard steel wheel .. even has the outer flange where the tire shop mounted standard tire weights ..
  8. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Hey dmhines post some more pics of the car when all the slots are on. Thanks Maverick73
  9. dmhines
    Cumming, GA
    I will ... I just mounted this one temporarily just now to conclude the discussion ... I am gonna hit the alignment shop soon so I can keep them mounted ... Here is a PhotoShop job to keep you until then :) I just copied the back to the front to get the complete effect ...
  10. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    really looks great
  11. MapleMav
    MapleMav Member
    '72 Sprint
    Looks great Dan. I too am a big fan of the slotted wheels.
