Shift Linkage Help
Discussion in 'Technical' started by Slider28, May 17, 2007.
  1. Craig Selvey
    the rod is there so that when you place the car in park....the column is rotated so that you can turn the car off and remove the key. When in gear......you can't turn the ignition back far enough in order to remove the key.
  2. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    THATS IT!!!!!! Thanks! even tho mine still works.. what do you call that bushing or groment so i can get a new one??
    thanks a million!
    cHAZ
  3. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Hey Craig, or someone. Please refer to post #8
  4. Craig Selvey
    The floor shift linkage is specific to the floor shift...and specific to a maverick I believe. I think it would be pretty simple to fab something up.
  5. Slider28
    Slider28 Member
    San Antonio, Texas
    I was just checking the car... even tho i have a FLOOR shift... on the colum of the sterring wheel by the turn signal, i have, seems to me MAYBE part of where a colum shifter may have been... its just a solid black piece about the colum that moves, but noithing it connected to it... If i move the FLOOR shifter OR that piece on the coluym that piece moves on the part under the hood that connects to the steering colum that you say controls taking out the key...
    CHaz.
  6. Craig Selvey
    O.K.....now you lost me.
  7. Slider28
    Slider28 Member
    San Antonio, Texas
    This might be fun to describe...
    inside on the steering colum first you have the steering wheel and then you have the colar with the ignition key and turn signal, then you have a metal collar that dont do anything, i CAN twist it and see the floor shifter move when i twist the colar. Was that more clear.. Had TOOOOO many screwdrivers when i typed that :)
    Chaz
  8. Craig Selvey
    O.K........that collar is "supposed" to turn with the floorshift. That is what I was talking about in my thread. It turns so you can only remove the key when the car is in park. Kind of a safety feature.
  9. Slider28
    Slider28 Member
    San Antonio, Texas
    Ahhh Got it!!!!
    Thanks
    Chaz/
