shackle ext?????
Discussion in 'Technical' started by 71nogo, May 20, 2010.
  1. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    i might be up in phx next week. pm me with your info and i'll give you a call.
  2. 1973Maverick357
    Cookeville TN
    Shackles can be bought for $15 at auto zone... Thats were i got mine but wrong idea... I am looking for a place to rearch them.
  3. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    essplain!!!!
  4. 1973Maverick357
    Cookeville TN
    I just went to autozone and they had them on their shelves... Ask the workers... They might be able to help you..
    EDIT: Part number is 13-4000.
  5. predfan2001
    I put Granada rear springs on mine and it raised it 2" over stock. I ended up having ot put lowering blocks on it to get it setting right. They are coming off soon and Maverick springs are going on.
  6. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    when i asked you to explain, i meant the "rearch" is that research?
  7. maverick75
  8. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    1973Maverick357 Your gold Maverick looks nice. Thanks for the info on were to purchase shakles, I have new shocks and bushings on my Maverick but I need the rear end a little higher.
  9. Dave B
    They make 1" longer shackles for Mustangs, these will work on Mavericks, but you'll have to re use your Maverick bushings (mustang used lager ones) plus, the bolt size will be a bit bigger, but you can get the Maverick bushings to fit. I have done this, and it works. Raised my car 3/4"
  10. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    The 15.00 lift shackles are a bad idea my hornet came with a pair of them dang things. They make handling very unpredictable and not fun.
  11. 1973Maverick357
    Cookeville TN
    Yeah i said it was the wrong idea but if thats what he has his heart on i helped him in his search for them..
  12. jncastell
    jncastell Member
    Ogden, Utah
    Thanks Guys! Good info so then to raise mine just a bit what part number will I need.
  13. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    That sounds like a much better idea. I don't trust the Chinese bolts that came in the shackles on mine, I replaced them with good grade bolts from the parts store. The Mustang ones will work and look factory like, plus have the better hardware. I may look into a set of those myself.
