roller cam gear.... which one do i need?
Discussion in 'Technical' started by mean_maverick, Apr 22, 2008.
  1. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Here's an example:
  2. Halebopp
    Halebopp Member
    Ankeny Iowa
    :thumbs2:AHHH I checked out the picts, I got it now, sorry to hijack, didn't mean to. Again you guys are the best !:tiphat:
  3. mavron 70
    mavron 70 Member
    R.I.
    1970 maverick 5.0 t 5 trans 59 ford rear with 4.11 cogs
    running a wysco hei distributor , 60 bucks on ebay...one wire...can buy an hei cap and rotor anywhere cheap cheap...comes with the right gear, I don,t care that it looks chevy, it works well
  4. mean_maverick
    I just ordered one for an '85 Mustang. It's specific for the DSII setup has a steel gear for the roller cam. just what i need, and only $50 for the whoel distributor (y)
  5. baddad457
    The cam gears on the distributor shafts come in two sizes : .467 & .512 (not 100% on these dimensions, but they're close) The smaller fits the points and Durasparks, the later fits the TFI distributors for the mid 80's-up applications.
  6. scooper77515
    Also, when shopping for them, make sure it is PRE-DRILLED...the ones that are not drilled are cheaper, and unless you have the correct tools, it may be difficult to drill it straight through so it lines up with your shaft.
  7. Corbin Johnson
    Great advice. :thumbs2:
  8. bmcdaniel
    bmcdaniel Senile Member
    When you install a new distributor gear you're not supposed to align it with the old hole in the shaft. You should press the new gear on the shaft at the correct distance from the housing and drill a new hole through the gear and shaft 90* from the original. There is no standard location for hole placement so there's no guarantee that a predrilled hole in a new gear will give you the correct distance from the distributor housing.
  9. scooper77515
    Glad mine lined up, then...:huh:
    Measured within specs after I installed it.
  10. bmcdaniel
    Whose gear did you use?
  11. scooper77515
    I used the cheapest one I could find with the hole predrilled, not knowing about what you said about the measurements.
    It was a mallory steel gear, predrilled, from Summit P#MAA-29418PD "Distributor Gear, Steel, Roll Pin Included, .467 in. Diameter Shaft, Ford, 221-302"
  12. mean_maverick
    an update to my distributor.... it works great! dropped right in w/o any problems or issues what-so-ever. I highly recommend to anyone to go to their local parts house and order one for an '85 Mustang, 5.0, manual trans,w/ steel gear. worth every bit of $50 (plus core) :thumbs2:
  13. scooper77515
    Wish I would have known that before i shopped all over for my gear...
    Did you use the entire dizzy or just the gear?
  14. newtoford
    newtoford Member
    New Castle Delaware
    i'll be doing that sometime this week. hope the kit working the counter gets me the right piece
  15. mean_maverick
    used the whole dizzy. it has the factory Duraspark plug-in on it as well so would be great for people running a Duraspark or Duraspark II setup
    double check the part number on the http://partsamerica.com website that way you'll know for sure you'll be getting the right one. took mine 2 business days to come in :yup:
