Resurrecting my 71 Comet 302
Discussion in 'Technical' started by RustyMack, Feb 13, 2022.
  1. RustyMack
    RustyMack Member
    Monterey, California
    1971 Comet 2d 302 4speed
    My high school bought car way back when it was new, now is out of the garage after sitting for a few years. It needs brakes and paint.
    It is one of those plain-jane models that Mercury built which had only a 302 and 3 on the floor. I bought it new. It now has a toploader 4 speed. But the brakes are in serious need of attention.
    I have 5 lug factory wheels. The easiest route would be 4 drums, assorted hardware and master cylinder. I saw a seller on Ebay that is selling disk brake setup for the 5 lug wheel. About $400-
    Not having power brakes, and having to install a proportioning valve would probably be required.
    What have others done to upgrade. This is purely an old mans ride now. Yeah the 302 is a bit hot. The toploader 4 speed was the best thing I ever did to the Comet. I just stumbled upon the retired 3 speed when pulling the car out of its spot. I had forgotten about it.
    Ideas?
    rickyracer likes this.
  2. RustyMack
    RustyMack Member
    The car in question
  3. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
    I installed that exact same eBay kit in mine. I went with a later model maverick/comet master and a new valve for disk/drum setup.
  4. RustyMack
    RustyMack Member
    Did it bolt up as they state? I have not had the drums off in years. So I have forgotten what its going to look like when the wheel comes off....
    Is a proportioning valve absolute on non power brakes?
  5. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
    They bolted right up, no problems there.
    I had to change out the main valve block from a Drum/Drum one to a Disk/Drum one.
    Then ran new lines from the master cylinder to the main block.
  6. RustyMack
    RustyMack Member
    the link I found last night I can no longer find. It was about 400 bucks for a complete non slotted setup Now I cant find that link....on Ebay
    It costs about the same as new drums, new cylinders new hardware, new shoes etc to put a disk brake setup on
  7. mojo
    Forget about the drums, going to disk are a No-Brainer! Probably best thing you will do, matching or exceeding the satisfaction going from 3 speed to toploader.
    jasonwthompson and Maverocket like this.
  8. RustyMack
    RustyMack Member
    Somewhere along the line in the past 5 years, I had brakes put on this Comet. I spent the day with the car up on a car carrier, I pulled each wheel and drums. Everything is brand new. I guess I am getting forgetful. Maybe I did brakes on it or had a shop do brakes. All I know is everything is brand new and not leaking. The dragging brake was over-tightened brake.
  9. 71gold
