Rest In Peace......
Discussion in 'General Maverick/Comet' started by justin has a 74, Sep 16, 2010.
  1. justin has a 74
    kentucky
    Ill just take off the glass, then you will have change!
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Join a mustang forum there great!
  3. justin has a 74
    kentucky
    I hate them forums, noone helps you!
  4. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    dude sorry to hear that your taking the maverick off the road hope you get it back running right soon
  5. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    somtimes taking a break helps RENERGIZE ones passion!
  6. simple man
    simple man Member
    Bunnell,Florida
    Please don't let it end up like the truck!:)
  7. JHodges
    JHodges thumper
    Dora Alabama
    I beat everyones offer $137.52
  8. mean_maverick
    and that's only because scrap prices are up... :rolleyes:
  9. JHodges
    JHodges thumper
    Dora Alabama
    quiet don't tell him that. lol
  10. BigDarrin
    BigDarrin Member
    Louisa KY
    Maverick
    Hey Justin what part of Ky you live in?
  11. maverickdragger
    maverickdragger GearHead
    Oneonta, AL
    1973 Maverick
    that sucks man. whats the deal? whats the running problem?. and the mustang? if its a 5.0 then you have the solution to the mavericks running problem. EFI TRANSPLANT
  12. darren
    Lord help us if Justin gets his hands on EFI. Dont think Stephan has the band width for that. :rofl2:
  13. justin has a 74
    kentucky
    Yeh, i would never attempt an efi swap. Something is eather wrong with the drivers side head (which i should have took off) or the dissy is screwed up. Im not in a hurry to find out which one it is so its 4 cylinder mustang time.
    Still backfiring through the carb ut its alot leass now, i can rev to 3 grand without backfire! Idles fine. Timing is spot on. and compression is 140 to 150.
  14. justin has a 74
    kentucky
    Morgantown, 30 minutes north of bowling green, 30 minutes east of russelville, and or an hour south or owensboro.
  15. 65 comet
    65 comet Member
    Colorado
    65 Comet Caliente Hrdtp, 65 2+2 Mustang Fastback 4 spd 53 F100 project 67 Ford 1 ton 4x4 project
    Justin, is the motor the original 74 motor?? If it is you might want to check the guides. I have seen that problem quite often over the past 30 + years with 73 to 77 302's. Cyl's 4 and 5 seem to wear guides and at low rpm's they run fine but valves start moving as rpm's increase which in turn creates popping thruogh carb. The weak points of the 302 are guides in 4 and 5 and rear main rattle at cold start. It is almost impossible to detect with comp test unless guide is real bad. Good luck.
