Relocating ignition coil
Discussion in 'Technical' started by 4dr73mav, Aug 8, 2005.
  1. 4dr73mav
    4dr73mav Member
    Weld County Colorado
    1973 4dr Mav V8
    Well, I fixed the alternator problem. Turns out that i shook loose an engine ground when I was working on all the electrical. The engine is running great now except I have to readjust the timing and the carb. I'll let you know how it goes. Thanks again for all the help.
    Jonathan
  2. scooper77515
    Bump that timing up to 10 BTDC. It should run and accelerate better, and shouldn't ping. I run mine 14, because any further forward, and I hit the upper radiator hose with my distributor.
