Rear Disc Brakes
Discussion in 'Technical' started by x72COMETx, Nov 19, 2015.
  1. 71gold
    doing it that way there is the E-brake issue. we flipped the pass. side bracket and then used the stock Mav/Comet E-brake system.
    he also sells a spacer, with ours we didn't use one and have had no problems.
  2. Paul Masson
    1971 Grabber
    I had the impression that the 91-95 units did not have any interference issues?? I helped a friend install the 96-02 units on his car and he ended up using 1/2" blocks between the leafs and spring perch to clear the top of the leafs. I didn't like the thought of a shim/block and lowering the car, so I ended up re-clocking mine.
    Thanks for the compliment Everett!
  3. x72COMETx
    x72COMETx Member
    Vallejo CA
    Another question on this, is anybody running 14 inch rims with this setup?
  4. junrai
    junrai Member
    rancho cordova ca
    you just need to come check out my car I have the disk already setup BUT I have 15" rims
    I know that the 14" slot mags I have on the orange comet gt I have had disk brakes but thats the front and oldschool calipers so the new ones may be different or larger :huh: next time youre out this way bring your 14" wheel and well try to bolt it on my disk set up then well see for sure :thumbs2:
    71gold likes this.
