Putting a fox body 302 in my Maverick. What headers should I use?
Discussion in 'Technical' started by 75Mav91Stang, Jun 6, 2007.
  1. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    In that case the only thing that is different is the water pump, front dress, and balance. My block is also a 90 5.0, but I used the older style front dress since all I started with was the short block.
  2. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    Different from what? The 5.0 I'm getting is complete so
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    The only thing you'll be able to use from the 1990 5.0 engine is the block, heads and oil pump. .... YOu need the correct:
    Oil pan, Oil pump pickup, distributor, timing chain cover, fuel pump eccentric, fuel pump, pulley set, water pump, 50oz offset flywheel, intake, carb, and probably some other stuff I have forgot about ..
  4. Dave B
    You'll need to change the oil pan.
  5. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    That is Charlie Ping's write up and it explains the differences just like Dan listed above, Engine Balance, Distributor, Water Pump and Cover, Oil Pan. And don't forget the firing order change.
    It is an easy swap and your doing the right thing by identifying what needs to be done up front.
  7. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    That seems like a lot to do now. Would there be a better choice of a 302 to use?
  8. scooper77515
    Just get an old 302 full engine out of an older car.
  9. maverick1970
    Missouri
    Ford installed the 302 in a lot of different vehicles. Unless you get one from a 70's Ford or Mercury car (front sump pan) you will likely have to swap a number of parts to make it work anyway.
  10. dmhines
    Cumming, GA
    I have a 1995 5.0 in my car converted to carb... It's the cheapest way to get a reliable roller-cam based engine ... however ... if you don't already have an old 302 engine to scavenge all the required parts from ... it can get pricey and challenging ...
  11. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Yeah I don't :/ So I guess I'm on the look for an old 302 from like a 60s or 70s Ford/Merc
  12. scooper77515
    May as well shoot for a 70s Maverick/Comet (no worries about the fit)...should be plenty out there. Maybe the 70s mustangs and Mustang IIs???
    Possibly the old Broncos? Torinos?
    Just tossing out ideas, someone else will correct me.
  13. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Is anyone on here selling a 302 from their Maverick/Comet?
    :x:
  14. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    All The Stuff You Need To Change Is Simple
  15. mavtricks71
    mavtricks71 Member
    mines a 94 5.0 fuel injection, CARBURATION SUCKS IN MY OPINION :)
