Parking brake ratchet pawl spring
Discussion in 'Technical' started by mike75mav, Nov 19, 2018.
  1. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I'm looking for a ratchet awl spring for a 1975 maverick. Will a pawl spring from a 1970-71 comet work?
  2. rthomas771
    The 70 spring is wrapped the opposite direction than the 71-up spring.
    Krazy Comet, Craig Selvey and Hotrock like this.
  3. Hotrock
    Munroe Falls, Ohio
    Damn rthomas771, how is it you have photos of these two springs?
  4. rthomas771
    I take things apart to see what make them tick...or in this case what makes them "click".
    Here's the difference between 70 and 71 parking brake. 1st pic is 70, 2nd pic 71-up, 3rd pic has 70 on bottom
  5. yellow75
    Tillamook Oregon
    Jeff is the official go to guy for lots of things it blows my mind what this country boy knows, if you dont have his how to links bookmarked then you better do it. He is a great person to know and am proud to have met him and talked with him several times.
    http://1bad6t.com/Maverick/maverick.html
    rthomas771 likes this.
  6. mike75mav
    mike75mav Member
    Bremerton, WA
  7. rthomas771
    No way to hook the spring in the housing and it will push the claw in the wrong direction if you did figure out how to install it. It would be easier to cut a slot in your housing and buy the early 70 pawl and spring from Melvin's...or buy a used parking brake assembly.
  8. rthomas771
    Thanks Mike. I try and say something nice about you some day. :cheers2:
  9. mike75mav
    mike75mav Member
    Bremerton, WA
    I need order the spring. So, I need the ratchet pawl and use both.
  10. rthomas771
    You will need to cut a funky looking hole in your bracket to use the new claw and spring. Or buy a used parking brake assembly to keep you from reinverting the wheel.
  11. mike75mav
    mike75mav Member
    Bremerton, WA
    OK, thanks for the info.
  12. Craig Selvey
    I have several used parking brake levers if I can help.
  13. mike75mav
    mike75mav Member
    Bremerton, WA
    That might be an option. I have the parts on order. If I can modify the brake than I'll get one. If you have one for a 75?
