new motor start up ???
Discussion in 'Technical' started by 71gold, Mar 15, 2009.
  1. 71gold
    i think i have it...:bouncy:
    i went back out to the shop and in just a few mins. i had it figured out........................................................................................:yup:
    :slap:
    i don't have a damn clue!!!...:yup:
  2. mav1970
    Well Frank, I hope you're not actually expecting to get that engine started without a damn clue. Not to worry though. You can find damn clues used, and in good shape, on Ebay sometimes. Keep away from any NOS damn clues. They're usually priced out of sight. I found one at NAPA under the part number OU812 that is close to a stock Maverick damn clue and it will work with a little modification.
    Glad to help :Handshake
  3. mavron 70
    mavron 70 Member
    R.I.
    1970 maverick 5.0 t 5 trans 59 ford rear with 4.11 cogs
    frank, honestly, you should invest in a light bulb repair kit,and if that does not work, tie it all up with 50 feet of fallopian tubing . also, a bucket of blue steam might jus help to clear the air
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I think it is a loose nut behind the wheel! :D
    FFA
  5. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Maybe do a compression test. Might have some bad valves or something...
  6. 71gold
    ....:eek3:...:rofl2:
  7. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    I'm guessing from your response that it is all new. I vote timing then.
  8. 71gold
    yes...all new..the timming is dead on...
    just not getting any fire from...coil...dist...at plugs...
    i changed out the coil a few mins. ago and still nothing...
    have 12V of power to the coil/dist.
    Jeff is stopping by Summit in the morning on the way down to my house and picking me up a ...new pick up...for the dist.
    ...maybe...:hmmm:...
  9. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    Quite odd and probably something simple.
    I guess you will figure it out. :)
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    In all seriousness Frank What is your ignition set up?
  11. Bryant
    thought you said that you had spark. ok if you dont have spark then your close to finding the problem. sence you have power to the coil, take the coil wire off the distrubor end and lay it over some place where you can see the spark jump. now put take the neg wire off off the coil and put a wire on it with one end striped that you can touch to a ground. now turn on the ignition, and you should be able to tap the ground wire to ground and lift it and get spark. if it sparks your coil is good if not then you need a coil.
  12. 71gold
    in my most serious typing...
    MSD-8352 ...dist....MSD-8352
    Blaster 2 ...coil...MSD-8202
    ...LFF...:Handshake
  13. 71gold
    ...:thumbs2:...always wondered how to check a coil...
    ...:cool:...
  14. CornedBeef4.6L
    no longer here
    Did you remove the dizzy?
    Are you using a Box?
  15. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Frank
    To check a coil for out put you give jeff the coil lead from the disy have him hold the coil wire in this hand tightly then crank the he$$ out engine and see if this eyes light up
