new champion radiator
Discussion in 'General Maverick/Comet' started by HOMERMAV, Feb 24, 2010.
  1. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Homer
    Can you use a tauras fan???? From the rad core to fan pulley you will need 4" and mount it upside down trim the shroud to fit.. If when you mount you puller fan DON'T use those damn zip tie things . Mount the fan to some straps across the rad and bolt them to the side straps where you would bolt your stock fan shroud.
    Jay
  2. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    i have a new 2600 cfm fan that i will be using and thats a good idea about the straps im sure i can fab up something to mount to the sides of the radiator where the shroud bolts.
    thanks
    john
