My maverick is a 4 lug
Discussion in 'General Maverick/Comet' started by steviejimmy, Sep 2, 2013.
  1. steviejimmy
    steviejimmy Member
    vista ca
    1972 ford maverick
    Do you ever have troube keep up on the free way?
  2. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    Before we rebuilt the 250 on my sister's car we put in a 200 c4 combo that my uncle gave us and it would do 80 on the freeway no problem.
  3. steviejimmy
    steviejimmy Member
    vista ca
    1972 ford maverick
    That's good to hear. I haven't how a chance to
    Get her running yet. just trying to get a Ida how it does normal driving.
  4. steviejimmy
    steviejimmy Member
    vista ca
    1972 ford maverick
    Got the vin
    2k91L150054
  5. Paul Masson
    1971 Grabber
    Well, it looks like your car originally came with a 250.
    I seem to remember this debate coming up a while ago. I did a search and found the thread:
    It appears that the 5-lug was "available" on small bumper 250 cars, but only if it was ordered that way. My bad...:whistle:
  6. steviejimmy
    steviejimmy Member
    vista ca
    1972 ford maverick
    I guess history does repeat it self. I should of looked
    Harder to find that thread instead of staring the same one.
    That you for all you help to understanding my car a lot more.
  7. Jamie Miles
    :Welcome:
    You shouldn't have any trouble keeping up with traffic with the 200. They're no power house, but they'll run with traffic just fine.
    The 4 lug pattern is 4 x 4.5" I believe. My '72 was originally 4 lug as well. Swapping the front to 5 lug is easy if retaining the drum brakes, all you have to do is bolt a set of 5 lug drums on, or you can get the spindles from a later Maverick or Granada if you want to change it to disc brakes. The rear is a bit more involved, as you have to source and swap in the complete 5 lug rearend, you can't just change the axles.
    Good luck.
  8. steviejimmy
    steviejimmy Member
    vista ca
    1972 ford maverick
    Thank you for the info.
    I think knowing what I know now there
    Is no need to change anything.
  9. Cpt. Bondo
    Cpt. Bondo Member
    Summerville, South Carolina
    (2) '72 Comet GTs, 68 Mustang
    If you're wanting custom rims for your car, check out the early Mustang parts companies. All 6 cylinder Mustangs from 1964 1/2 to 1968 had the same 4 lug rims as the Maverick & Comets.
    You're not going to find much though unless you want to go modern 16 & up sizes from a custom wheel manufacturer that will drill the rim to any lug pattern you want in the rims. Be fore warned though, custom milled rims are going to cost big money to have made.
    I hope this helps some,
    -Scott H.
  10. Bryant
    stop by any time!
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The 5-lug conversion really is not hard to do, and that is what I recommend.
  12. rthomas771
    You will also need a 5-lug hub. 5-lug drum won't fit a 4-lug hub.
