my car is spitting and sputtering like CRAZY!!
Discussion in 'Technical' started by random hero, Mar 18, 2007.
  1. skaz
    skaz a.k.a. Steeb
    Phoenix, AZ
    74 Maverick, 73 El Camino
    Well.. go outside, preferably in a street where no one is driving.
    Remove the fuel line going into the carburetor from the fuel pump. Lay the hose over the side of the car or get someone to hold it towards the street. Pump the accelerator once or twice then turn the engine over. If gas shoots out further than a couple of inches, you're probably okay on the fuel pump.
  2. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    i just went out and popped the distributor cap and saw a small clip just laying inside, so i looked around inside the distributor and found a small rod with something overlpping it that was loose...so i put the c clip over the loose piece and connected it to the rod....BAM!! it works ok now...still a little wierd...but no where near as bad, i need a new c clip, the old one is so loose
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Sounds like the rod for the vacuum advance. The auto parts or hardware store should have a selection of C clips for a replacement.
  4. random hero
    hudson valley
    1972 maverick
    the rod was stationary, but the plate that overlapped the rod went into the vacuum advance, not a big plate, more of a 1/4" wide plate that went into it.
