My attempt at a 71 street machine
Discussion in 'Maverick/Comet Projects' started by kansasGRABBER, Nov 20, 2014.
  1. kansasGRABBER
    kansasGRABBER Member
    Hoisington, ks
    1971 Maverick Grabber
    Forgot about the bump stops. Plans are to reinstall them just didn't know if you had a reason not to or something. BTW I was thinking about horizontal forces. Wouldn't you want the upper reinforcement to be on the sides?
  2. kansasGRABBER
    Hoisington, ks
    Bryant thank you for your knowledge and willingness to help me. What is your opinion on cowl support? Like these IMG_20141130_214238.jpg P1030878.JPG
  3. Bryant
    the stiffer you can make the body the better the car will react in all situations. the only thing to watch out for is weight.
    boxing the control arms is just that. creating a box. that drastically eliminates the amount of twist of the arm. will gain boxing both the upper and lower arms. top rangers belly bar is a really good piece to add. it ties the lower control arm frame bolts to the belly bar.
    welding up as much of the seams in the car helps a lot also. especially around the suspension mounting areas.
    im really interested in your build. i bought my white car full of high end stuff, but my comrick project plan is really similar to yours. it will be built with a lot of diy stuff like your doing. ive done and am still doing lots of research on what i can do and how to do it. you are on the right track, i just see the few little things in your build that could be done a little better to give you more flexibility. your doing great and you will have a car of great levels of performance.
    with my recent endeavor into autocrossing, ive really learned the value of tires. my white car has staggered tires. wider in the rear than in the front. thats not a popular way to set up autocross cars. they like to have the same size all the way around. that way the traction coefficient is even all the way around.
    keep up the good work. it looks like your putting lots of time into this and making fast progress. keep it up.
  4. kansasGRABBER
    Hoisington, ks
    Been awhile since I've updated haven't had much time thru the holiday season. But here is the little bit I have IMG_20141228_163533363.jpg built the alternater bracket and tensioner
    Started on a shock tower brace
    IMG_20150127_191315946.jpg and got a new windshield with new front and rear gaskets headliner should be here today.
    Btw anyone looking for gaskets PRECISION makes very high quality gaskets. Prp.com
  5. kansasGRABBER
    Hoisington, ks
    Got the headliner last night. IMG_20150128_182430927.jpg i used foam bumper wrap as a light insulation before installing the headliner IMG_20150128_221231121.jpg after install no heat gun yet.
    Tonight the glass goes in
    Paul Masson likes this.
  6. Paul Masson
    1971 Grabber
    Making good progress! Looks good!!
  7. mav1970
    Moving right along there and looking great :bananaman:
  8. kansasGRABBER
    Hoisington, ks
    Glass tinted and installed IMG_20150129_210100260.jpg and a little polishing IMG_20150129_113536343.jpg
  9. bkcha
    bkcha Member
    Pooler, GA
    71 Gabber
    Looking good! Can't want to get back and get my hands on mine....
  10. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
  11. kansasGRABBER
    Hoisington, ks
    While I'm waiting for the budget for more parts I started on body work. IMG_20150201_164032178.jpg IMG_20150201_185706390.jpg there were a few more dents than I expected, however the only one more than a heavy hail dent is right over the passenger door and some small creases over windshield.
    I didn't think about dents before installing the headliner.:slap:
  12. schroensr
    1975 Mercury Comet
    I also installed a new head liner to. Only to Tate the whole car apart completely down to bare metal.
  13. kansasGRABBER
    Hoisington, ks
    Got the mud work done, etch primed, and primer surfacer shot last night. IMG_20150202_201047699.jpg IMG_20150202_202630195.jpg
    Next is the quarters
    Dave B likes this.
  14. kansasGRABBER
    Hoisington, ks
  15. kansasGRABBER
    Hoisington, ks
    Got the second coat of primer on the roof and quarters. Fenders, hood, and decklid have filler, self etch, and first coat of primer. Hood also has been jammed.
