muffler support
Discussion in 'Technical' started by fredee, May 8, 2006.
  1. fredee
    fredee Member
    South MS.
    1971 comet
    What is the best way to support a muffler on the drivers side when running duals? No real support bracket on that side. Anything besides just drilling a hole through the floorpan.
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Yes you can hook a hanger to the top shock mounting bolt. It may require welding 2 strap hangers together. F1771 ipc number
  3. Mavaholic
    I've used the floor pan. It ends up under the seat and you can make a reinforcing plate to strengthen it.
