missing problem
Discussion in 'Technical' started by 4557morris, Jan 16, 2012.
  1. 4557morris
    4557morris New Member
    WV
    1974 ford maverick
    I have a 1974 2 door maverick,250,automatic.It has a engine miss.I have replaced distributor,points,condenser,plugs,plugwires,coil,voltage regulator,starter.Still has engine miss.It gets worse when you get above 45.Also,tried to install rpm gauge,the needle would hardly move.Hook it up to a 68 ford truck and it worked fine.Any suggestions?
  2. 71gold
    ain't you glad you ain't driving a P.O.S. Chebby...:thumbs2:
  3. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    Electrical area seems covered, what about the alternator? What about a clogged fuel filter?
  4. Bryant
    what is the dewell reading of the points?
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Vacuum leak or faulty EGR
    Make sure the Tach is set to 6 cylinder mode.
