Major electrical issues
Discussion in 'Technical' started by moby911, Mar 20, 2009.
  1. Bryant
    i wouldnt waste money on a starter. do the test light thing first.
  2. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    That is good advice. When you are hooking up that freshly charged battery are you getting a big spark? I would think you would be.
    You will need to do like the other 2 told you though and get an amp meter or test light between the battery and the circuit to find the short. Sounds like a large draw so shouldn't be too hard to find
    clint
  3. moby911
    moby911 Member
    1977 maverick
    **UPDATE**
    Okay so I finally bought a new battery for it and it started right up.The only problem is that the battery reads 12.3 while the car is running.I tried the test light thing and the light was on and even when I pulled the fuses it stayed on.One thing I'm concerned about is (I have the steering wheel off by the way) these two little button things in the steering column near the blinker assembly that sparked when I tried putting the old steering wheel back on.It also read 12.3 volts on one of them.If you don't know what I'm talking about then I can try and get some pictures tonight.
  4. Bryant
    try unpluging the alternator. if the light goes out then the diods in it are bad. thats about all that is left, unless the power wire going to the fuse block is grouding out some where.
  5. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    the 2 little "nubs" in the column are for the horn.
    Robb
  6. justin has a 74
    kentucky
    yellow box????
