It was stuck in my rear end, Bryant got it out . . .
Discussion in 'Technical' started by mashori, Sep 17, 2009.
  1. Bryant
    hey i love my job. i get to pound on rear ends and lube them up all day long. :rofl2::dance::bananaman:thumbs2::rofl2::smash:
  2. yellow75
    Tillamook Oregon
    Got to worry about those Cali guys, they dance to the beat of a different drum.
    Well at least one of them should have the cure
  3. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    I was afraid to open this at work!
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    The center section is done! I could have had it installed today but I couldn't get the alternator fixed in time to take it to Bryant's shop.
    Bryant had the housing straightened, it actually was a little bent. He painted it hot pink (as requested) and I got to watch him take apart the open diff center section and build my Auburn posi. I guess the overall job is straighforward if you just play legos and bolt things into place. But . . . there is a lot of little steps that I feel like get missed unless you do this for a living. Also, the special tools that are needed make a huge difference. It looks like Bryant had a lot of these custom built. But anyway, here are the pics, it was awesome see it getting installed in person.
    He spent a long time cleaning the parts, pretty meticulously with some crazy smelling solvent.
    This is after the parts got totally cleaned up, the housing was orange but was totally black, that was kinda interesting to see.
    Here is Bryant cleaning the parts. I'm not sure why he has that look on his face, maybe something I said about his Maverick. :rofl2:
    You can't see it but he has specific sized taps that he uses to hammer those things into place and he actually spent some time deburring and cleaning specific surfaces in order to make sure everything seats properly. That's the things that I could see someone skimping out on and having problems later.
    Here is the bearing hammered in. The retainer sits on top of it but I don't have a pic of that.
    This part was interesting. He was trying to make sure he had just the right amount of preload and he had this fancy little tool to make those adjustments. He was pretty close eyeballing it but still went back to dial it in.
    Bryant mentioned that this part is important to really get everything to work properly and to make the diff last longer and not excess noise. He painted this stuff on and spun the diff trying to see how well the teeth lined up by looking at the wear.
    Here is the result after spinning it and he said since the parts were good quality everything turned out well without needing adjustment.
    No pink available so he went with black
  5. maverick75
    Sweet! great work, whenever i save up enough money to hot rod my 8" i know where to go :)
  6. Jamie Miles
    Alto, GA
    I've had a few
    Awesome!!!
  7. blugene
    I do enjoy your write ups. Nice work by both of you. (y)
  8. baddad457
    :dancing: This sounds Ghey.:rofl2:
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I don't think my rear end will ever be the same!
  10. baddad457
    :D :DMaybe the next thread you start, try and think of a better title........................:huh:
  11. Bryant
    you just have a dirty mind. this is a car board and that is all we talk about in this tech section. :rofl2:
  12. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Ok, was I the only one that noticed that he was going to paint it pink?!?
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Bryant said I will have a better take off with pink. He said it'll make my 3.25 gears pretty much a 3.69. He also mentioned it will make my rear end smoother and if I decide to really give it a good pounding out there on the tracks on a friday night, it'll go the distance. Those were his exact words
  14. Bryant
    we all know that pink is the fastest color out there
  15. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    You guys are bad...on SO many levels!
