Inline 6 gasket vendors?
Discussion in 'General Maverick/Comet' started by borjawil, Dec 14, 2011.
  1. borjawil
    borjawil Member
    lansing mi
    1972 Ford Maverick Sprint
    I had to remove the head on my i6 200 to have the manifold bolts machined out. So now Im looking for a place to but the head gasket and valve cover gasket. Im on a very tight budget so something like $50 or under for both would be good. Also tips on putting it back together to get a good seal, should I use anything on the mating surfaces to help seal it up?
  2. Dave B
    National Parts Depot, in Canton has a 170,200,250 gasket kit for $75.95, or just the head gasket listed for $35.50.
  3. maverick75
    Get a mechanics straightedge and a feller gauge and check for straightness on the head/block.
    If it's too far off you might end up wasting your new gaskets.
    Some people spray copper spray on the gaskets, I prefer to use a good felpro MLS gasket and nothing else.
    One thing that will happen is your compression ratio will drop slighty. Since no one reproduces the stock thin gaskets and the only ones readily available are around .050 thick.
  4. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Shop e-bay you can get opened gasket sets cheap
  5. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    No sealer required on todays' head gaskets. As far as the valve cover gasket...I always use rtv sealant and glue the gasket to the valve cover and that's it.
  6. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    felpro headgasket are $25 at any auto parts store (autozone,orielly,etc)
    and the valve cover gaskets are $10.
    no need for any sealer anywhere
  7. borjawil
    borjawil Member
    lansing mi
    Gotcha, just order one from autozone! Thanks guys!
