ignition for a 78 302
Discussion in 'Technical' started by LSU2010, Sep 2, 2009.
  1. Joe Dirt
    v8 mustang II's have 2.79 or 3.00 gears like our mav's
    V6 cars have 3.55 for manual,3.45 for auto
    4 cyl cars could have a 3.45 or 3.55 8" but most had the small spicer style rear end.
  2. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    '72 mav 2dr, '70 mav 2dr
    unless the guy changed them (i'll ask) that's what I have now. So, they are special because they're mustang II stuff? I have maverick parts to put in their place if this is a project funding option.:scratchchin:
  3. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    yea the guy got the motor out of the car and built it for the maverick I just bought but he never put it in. the other guy that got the car used the suspension and rear for his street rod.
    That thing is rather obnoxious looking. I think I am just going to get the racing wires and a street fire.
  4. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    so to recap-
    I am looking at getting the following:
    already have distributor and cap, msd say should use new ones....
    the ford racing wires
    some spark plugs
    the MSD street fire
    the only other thing I require is a coil which I can get el cheapo at any parts store?
  5. baddad457
    Coil has to be one for a CD ignition system. I think the one's for the Duraspark arer OK for this.
  6. Joe Dirt
    the oil pan,insted of having a gradual bend to the sump in the front has a more of a 90* angle.
    Mustang II V8s used a special reduced-diameter C4 bellhousing, torque converter (higher stall), 141-tooth flexplate, block plate, dust cover. Also special
    motor mounts, oil pan, oil pump pickup, and accessory mounting brackets.
    Should help fund your project(y)
  7. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    from what I remember the oil pan is definitely as you described. although it is dinged up from being stored sitting on the pan. this is exciting. I will keep you informed of my findings...
  8. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    was looking for a coil chart for the MSD5520 or something of that nature. FOUND this grabber at the top of the street fire webpage -> http://www.street-fire.com/
    anybody's?
