I6 to V8
Discussion in 'Parts Interchange' started by mavmandan, Jun 26, 2006.
  1. mavmandan
    mavmandan Member
    Payson Az.
    1970 Mav, really trashed right now
    I pulled the six out today. It was incredibly easy for my first one. If I was to use the aod and modify the tunnel will the drive shaft on the mav be the right length.
  2. stmanser
    Davenport, Iowa
    i dont use the v8 cross member... so i know it isnt requried.. but it does beef up the front a little bit
    the swap is easy enough to do.. just takes a little patience..
  3. afjaybird
    afjaybird Member
    vandenberg afb
    70 maverick grabber
    so i dont have to use the belly bar?
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I ran mine for many years without the v8 crossmember. You can also get by without the double hump trans crossmember.
  5. mavmandan
    mavmandan Member
    Payson Az.
    Ok I was putting the 302 in today and the exhaust maniflod hits the shock towers. Will after market headers be smaller.
  6. newtoford
    newtoford Member
    New Castle Delaware
    there are a few sb maverick headers on the market that fit stock shock towers
  7. mavmandan
    mavmandan Member
    Payson Az.
    do you know which brands.
  8. maverick1970
    Missouri
    What shifter will you be running. Most of the headers are designed for floor shift cars, however there is someone on the forum that has modified the column shifter to work. I personally like the Hooker 6901 headers. If you want to run cast manifolds you will need to find a set for a Maverick/Comet.
  9. newtoford
    newtoford Member
    New Castle Delaware
    summit makes a set for $95. SUM-G9031
  10. mavmandan
    mavmandan Member
    Payson Az.
    I'm going to have a Hurst floor shifter nicee. Do u know if the hooker 6901 are any thinner i mean don't pertrude so far out from the black as the stock manifolds do.
  11. don graham
    i have 6901's on mine. the passenger side goes in pretty easily. the drivers side you have to jack the engine up a couple of inches, and they do go in from the bottom. the higher the car the better, within reason of course.:)
  12. mavmandan
    mavmandan Member
    Payson Az.
    what year of Mav is it
