I need some help? What if I broke a bolt on the header?
Discussion in 'Technical' started by raydenaomi, May 24, 2010.
  1. Bryant
    is the broken bolt going through the header into the head or is it where the exhast pipe meets the manifold?
  2. 71gold
    i have used it on...carbide..bits...:tiphat:
  3. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Seems like a good reason to use carbide bits when drilling out a broken bolt.
    Here's a quote from the Internet.
    Never could think of a use for left-handed drill bits but, there it is.
    I suggest you remove whatever part (exhaust manifold? head?) contains the broken bolt and take it to a machine shop. They shouldn't charge you much to remove the bolt. Since you've already done several repairs, if you pick up a repair manual and follow it you should do that OK. Really like your attitude. Good luck with it.
  4. 71gold
    the shop i use charges $25 a bolt. i took a head in once that had 6 bolts broken off in it...
    ...:bouncy:...
  5. raydenaomi
    raydenaomi Member
    Louisiana
    1976 Ford Maverick
    Re: raydenaomi
    I think it's where the exhaust pipe meets the manifold? Do you have a website so I can look at the parts you have? Thanks for the help:tiphat:
  6. raydenaomi
    raydenaomi Member
    Louisiana
    1976 Ford Maverick
    Thank you so much for the bit of information. This should get me going in the right direction. I feel confident that I can handle the task. I think I will look for that left handed drill bit. Carbide? I'll look at home depot. Really appreciate the help again:bananaman:Handshake
  7. raydenaomi
    raydenaomi Member
    Louisiana
    1976 Ford Maverick
    25 a bolt, i think i can handle that. :yup: 6 bolts broke off. Thanks, now i dont feel so bad. :p
  8. 71gold
    being there it will be a piece-of-cake. just remove the manifold and take it to a machine shop...:thumbs2:
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Suggestion: Get a cheap digital camera and take some pics and post here so we can see exactly what you have there. It might be done on the car, then again, you may have to remove some parts to get the bolt out. I don't want to sound discouraging, but from your posts I gather that you are sorta inexperienced in auto mechanical work, and sometimes you can do more damage than good if you don't know what you are doing. We have all been there, and some of us, me included, learned the hard way, by tearing up stuff trying to fix something else. We are here to help, so ask away!(y)
  10. 71gold
    update please...:yup:
    Frank...:bouncy:
