Hey guys, I got a couple simple questions...
Discussion in 'General Maverick/Comet' started by ShuttleMav, Apr 11, 2006.
  1. ShuttleMav
    ShuttleMav Member
    RustStop uses electrical impulses to prevent rust from occuring..... no sprays or liquid's at all....
  2. scooper77515
    interesting...never heard of it. Is it battery powered, or is it a solid application like adding zinc strips to a ship's hull (I think it is zinc?)?
  3. ShuttleMav
    ShuttleMav Member
    It's actually a little kit that you hook up to your car battery with 4-8 nodes that go on your car.... if you go to google and type in rust stop you can find the site.....
  4. Jamie Miles
    Alto, GA
    I've had a few
    Sounds a little far fetched to me, but what do I know. I would just get some POR15 or similar.
  5. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    This sounds sort of like the sacraficial zinc pieces that are attached to the prop shafts of boats. They are attacked by electrolosis instead of the steel or brass parts. Some compaies even make zinc nodes for the cooling systems of cars to reduce the corrosion effects of electrolosis in the cooling systems. Radiators, heads water pumps, hose fittings, etc.
  6. scooper77515
    jay, that is what I thought, but he says his actually works off of an electrical current from the battery... :huh:
  7. ShuttleMav
    ShuttleMav Member
    I think what happens is it creates a negative charge on the metal so the iron cannot oxidize..... or maybe im talking out my a**hole, I dunno...I'd believe it if thats what I told me.....
    http://www.ruststoponline.com/how-does-ruststop-work.html
    Go there, read about it.... you make the decision....
