Help please!
Discussion in 'Technical' started by native, Mar 29, 2014.
  1. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    If your mtr is 10 & a half or less comp ratio,don`t run over 34 degrees of total advance,it won`t help you.Also if your rocker arms are adjustable,back them off a 1/4 turn at a time as they could be a little tight.Just had the same problem on a 283 chevy w/ same carb,backing the valves off made a big diff,it had a cam comparable to yours.
  2. native
    native Member
    michigan
    1972 maverick
    Thanks for the info Dan!
