help! confused....
Discussion in 'New Members Forum' started by stargazer318, Nov 2, 2014.
  1. stargazer318
    stargazer318 Member
    1975 comet
    Hi all. New to here. I got a75 comet, turning it into a73 GT clone with the power train out of a 89 5.0 with the 5spd tranny. The problem I'm having is this; seems to me the engine is sitting on too much of a angle. I'm about to cut the traany hump out but everything I read says it's not needed. Doesn't the engine need to sit a little more level?
  2. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
    Start a thread in the technical forum and you'll probably receive more answers to your question. Good luck!
  3. stargazer318
    stargazer318 Member
    1975 comet
    Hi all. Need to tap into all the knowledge out there. Confused. Got a 75 comet. Installing a 5.0, 5spd out of a 1989 stang. Problem I'm having is this. The engine is sitting on a angle. About to chop out my tranny hump, but everything I read days it's not needed. Isn't the engine on too much of an angle? Won't affect oil pressure?
  4. stargazer318
    stargazer318 Member
    1975 comet
    Thanks just did! Cheers...
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  6. mav1970
  7. 71gold
    :Welcome:
    do you have the correct motor mount stands and are they installed correctly?
  8. rthomas771
    The brace tying the frame rails together is part of the structural integrity. It was put there on propose. If it wasn't needed then Ford wouldn't had wasted time and money designing/manufacturing/installing them on unibody automobiles
  9. Krazy Comet
    Engine should set with a very slight rearward tilt, if not the U-joints will be in a bind and you'll get lots of first hand experience on replacement...
