Heads
Discussion in 'Technical' started by Mavaholic, Aug 30, 2007.
  1. grbmaverickmo
    Aquashicola, PA
    I f interested I have a set of 70 351 heads. I `d sell you when you come up to get them seats.
  2. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    I have a chance to buy dart Sr heads with 202 valves..will they have enough
    clearance on a 351 1969 motor with stock pistons,,the cam has 550 lift?? thanks
  3. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    I wish I had taken more pics of my wifes DOOE Windsor heads but here is one .
  4. baddad457
    It's not the total lift you need to worry about but how the total valve timing events have an effect on piston to valve clearance. Namely on the exhaust and intake stroke follwing it. In the exhaust stroke, the piston is chasing the exhaust valve up the bore, then around TDC, as the exhaust valve is closing, the intake starts to open, then chases the piston back down bore. 2.02 intake valves usually don't fit the clearance notches in the stock pistons, that too comes into play.
  5. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    why not use a set of gt40 heads?
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    2.02 heads are generally NOT trusted on an engine with stock pistons and .500"+ lift cam. Your combo might, but using the 'safe' rule of thumb, you probably should plan on pistons or at least mods to your current pistons.
    Which ones?
    If you are refering to the stockers, there are better heads out there than those. Especially the 69-73 351w heads after they have been ported. Those heads have been proven to outperform some aftermarket heads after professional porting. Labor cost and weight are the 2 big drawbacks for any stock iron head.
  7. 1973Maverick357
    Cookeville TN
    This thread is 2 years old..
  8. ratio411
    ratio411 Member
    Pensacola
    For my part in the thread...
    I don't like resurrections either.
    However, my response was to posts from yesterday.
  9. 1973Maverick357
    Cookeville TN
    Yeah i know im talking to the guy that ressurrected it
