Headliner
Discussion in 'Technical' started by MarulMav, Mar 16, 2006.
  1. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    When I bought my car the headliner was gone except around all the seals. My question is how do you know which order the bows go in?
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Install the bows without the headliner and eye-ball it...
  3. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    I had my done by a pro. He had to take out the back glass but not the front. Looks great.. Dean
  4. tom butas
    tom butas Member
    West TN
    Sold my 1974 Comet - Looking super nice 73 Maverick near Memphis
    Quote here $150 and another $100 for glass man.
  5. Mighty Mouse
    Mighty Mouse Member
    Belton, TX
    1973 Comet
    Here's a dumb question....but I'm new so it's allowed.
    My headliner is actually very very nice in my new beast...but some jackass cut it...or so it looks. Just one cust about 8 inches or so...is there a way to repair rather than replace? Duct tape was my answer...but I'd paint it to match. :)
  6. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    in one of the rear corners i bet
  7. Mighty Mouse
    Mighty Mouse Member
    Belton, TX
    1973 Comet
    actually yeah, the rear corner is messed up a bit....I just noticed, but the cut is in the passenger side, I guess someone thought it would be cool to cut it.
  8. MaverickGrabber
    Cardington, ohio
    no I’m sure it was not cut ...they tend to rip there ...its a tight point and over time it just splits ..looking like it had been cut......i have seen them glued back together ..but it wont be long it will not hold ..Dry rot sucks
  9. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    I installed my headliner all glass was out . I used the glue from the supply house the high tack stuff started in the middle and work my way right an left pulling it tight as you go an let the glue set up ( many clamps later ) . then going to the rear an repeat . Then to one side then the other always pulling it as tight as possable as you go . When the glue is set up use a heat gun ( hair dryer ) to shrink up the loose areas ( be careful not to
    much heat in one area you will melt the materal ) .
    I hope this helps jay
