Got my DISC BRAKES installed. EXCITED! PICS INSIDE.
Discussion in 'Technical' started by 510madmav, Jul 22, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I got my front brakes conerted to disc, had a disc/drum prop valve installed and still didn't have a uge difference in braking power. If you read through the many disc conversions, not a lotta people say that there is a huge improvement after the conversion. But I'm happy because I have no clue how to work on drums but discs I'm comfortable with.
  2. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I don't know much about the difference between drum+drum and disc+drum braking power and general feel, as I've never driven a drum+drum Maverick. But I will say there's quite a difference when you go from disc+drum to disc+disc.
  3. Jamie Miles
    Alto, GA
    I've had a few
    Still running the drum/drum master cylinder and prop valve on my '72 with front discs. The car stops excellent, far less pedal effort required, and it stops straight and true every time. Night and day difference in my case between drums and discs, best thing I ever did to the car was put discs on it.
  4. 510madmav
    510madmav Member
    San Francisco bay area
    1973 Maverick
    how do i get my pedal firmer and higher?
  5. Joe Dirt
    give the pads time to seat into the rotors sometimes ive seen new pads give a softer then normal pedal in some cases.
  6. rad1j
    rad1j Member
    filer daho
    73 grabber
    eAch set front and rear need at certain amount of residual pressure this is the reason for the vavlesi know there is one for front and on for rear i have installed disc on my fairlane and it does make a differance ,if there are no pressure vavles the shoes and disc pads have to travvel farther to make contact because there is no residual pressure in the line,hence forth soft pedal, i tryed to do it w/o the valves and was not happy with the result.with the vavles it stops on a dime its a station wagon and it is a lot harder to stop than a maverick,i dont think the drum on drum has the proper residual valve in place in the stock config one other thing at 137.00 mph its really hard to stop any car i know i did it at bonneville on drum on drum and it also didnt make the 1/4 mile shut down i took road off the course at over 50 mph and had to replace drivers seat (MASSIVE STAIN)
  7. sierra grabber
    sierra grabber Certifiable
    northern nevada
    i can tell you that i notice a difference big time, drove it for years all drum and now years disc\drum. takes about the same effort for regular driving but stops at least a couple feet shorter. in a panic or high speed stop or in the rain, NIGHT AND DAY!!!!:dance::thumbs2:
  8. darren
    Oh no not the residual pressure topic again. Needs the disc master. Case closed.
    Got this from a post I put on another thread. Its a good explanation. Did my conversion to disc and the drum/drum master does hang the pads. Put the drum/disc on and drag normal. The residual valve in the drum/drum master will put around 50 pounds of force on the caliper piston/pads if its working correctly at 10 psi.
    http://www.cometeastcarclub.org/PDFs/BrakePlumbing.pdf
  9. 510madmav
    510madmav Member
    1973 Maverick
    case closed. i like that
  10. sierra grabber
    northern nevada
    BTW i got my entire setup including prop valve from the hayward PNP in the 90s. the master was the only part that ended up needing to be new and that was because i pulled it off a power asist mav :)
  11. 510madmav
    510madmav Member
    1973 Maverick
    man you oughta come back down here and meet up. are you near Carson City? i have a buddy that lives in carson.
  12. sierra grabber
    northern nevada
    yeah i work in carson and live 20 min south. definately hoping to get a bay area meet up going on as i am out there quite often. wont be bringing the grabber for a while though because i am replacing a shock tower right now....
  13. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    So what master cylinder would one use if going to all disc manual system on a Maverick?
  14. sierra grabber
    northern nevada
    exploder?? someone used a geo.....
  15. darren
    Good question. Does anyone know of a all disc master that fits?
    Next question is a manual all disc master out there? Versailles would be a power master I assume.
