Fuel tank questions
Discussion in 'Technical' started by navyfc117, Feb 14, 2013.
  1. navyfc117
    navyfc117 Member
    El Cajon, CA
    2014 Exploder, 2006 F250 and 73 maverick
    First off, where can I find a new fuel tank? Mine is rusted on the inside.
    Second, I don't think my fuel pump is working. What is a good way to test this. The fuel filter is dry as a bone even after turning the engine over for a minute.
    This is a 1970 6 cylinder.
    Thanks :thumbs2:
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  3. navyfc117
    navyfc117 Member
    El Cajon, CA
    Thanks for the reply. I see they have one in LA. I would have to ship it because I don't feel like dealing witht he traffic. I was really hoping to get this car on the road by this weekend :(
  4. navyfc117
    navyfc117 Member
    El Cajon, CA
    So i placed the hose from the outlet of the fuel pump in a cup of water and it was making bubbles. the hose from the fender to the fuel pump witht he filter is not clogged. Why is the gas not making it from the tank to the fuel pump?
  5. Bryant
    one of the rubber hoses may have a hole in it or the steel line may have rusted and have holes in it.
    kirks radiator on magnolia in el cajon can repair and clean gas tanks.
  6. rthomas771
    Fuel pumps go bad if they are not being used over an extended amount of time...the diaphragm dries out.
  7. 71gold
    have you pulled the sending unit and inspected it?
  8. navyfc117
    navyfc117 Member
    El Cajon, CA
  9. navyfc117
    navyfc117 Member
    El Cajon, CA
    I drained most of the fuel from pulling the hose off the sending unit. It is not clogged. However it needs to be cleaned or replaced.
  10. navyfc117
    navyfc117 Member
    El Cajon, CA
    Tank is going to Kirks Tomorrow.
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    You getting it renu'd?
  12. navyfc117
    navyfc117 Member
    El Cajon, CA
    I am. He said it would take a couple days. Hopefully be on the road by next weekend. Still have no clue how the transmission is.
