Front Drum Brake Hub
Discussion in 'Technical' started by hpmccloud, Jul 13, 2014.
  1. hpmccloud
    hpmccloud Member
    1973 Mercury Comet GT
    On the 1973 Mercury Comet the front brake drum seems like the wheel hub/bearing assembly is built into the drum or pressed in. Do we need to get it pressed out and pressed into our new drum or is it just rusted in really bad? I haven't been able to find any information on it anywhere.
  2. mercgt73
    mercgt73 Member
    Press out the wheel studs. Then you can remove the hub from the drum easily.
  3. Dave B
    Some of them can be crimped, you need to grind the crimp off, then remove the studs, and replace them.
