Ford 302 Mexican block
Discussion in 'General Maverick/Comet' started by Positively Ralf, Jul 19, 2010.
  1. starsky74
    starsky74 Technician
    Hackberry Louisiana
    yes but make sure you have the correct flexplate, also someone here sells the crossmember for it
  2. Positively Ralf
    Yonkers, NY
    1974 Maverick
    Hey guys, I have a question for you. will the late 90s explorers have these 302s in them? Reason I ask is because I found out my brother in law's best friends works at a junkyard and when I talked to him he says his place only has a 96 and 97 explorers already parted out.
    Cheers!
  3. jkc302
    jkc302 Member
    Dearborn, MI
    Toooo many!
    I'm not sure what years they had 302's in them. I have a 2000 and it's a 302.
  4. maverick75
    96 and 97 Will have 302s. that was the transistion period of the P head. So you have to decide which ones you want.
  5. Positively Ralf
    Yonkers, NY
    1974 Maverick
    What's the biggest difference between the P heads on the 96/97 Explorers and the GT40 ones?
  6. Fro
    Fro Member
    Joplin Mo.
    19691/2 maverick 1971 maverick
    96 and some early 97's had the gt40's which have 3 hash marks on the front of the heads and a F3ZE number on them, and the P heads have 4 hash marks on the front of the head and a F77E part number on them, the GT40 head will fit on any 289- 302- 351W without any mods, the P head may require some header mods.
  7. Fro
    Fro Member
    Joplin Mo.
    also the 5.0 engine was used in explorers from 96 to 2003, also I have a 99 explorer motor in my wifes 65 mustang (injected) and it fits very well, I think they are a little tighter on hood clearance than mavs.
  8. maverick75
    To add To the info listed above. Theres no headers made for the P heads in mavericks. Chirt has them on his car. But he had to buy spark plug wire arms. And last i checked they were really really expensive. Like 35 bucks each.
  9. Fro
    Fro Member
    Joplin Mo.
    I recently read somewhere that someone is making a special short spark plug that helps with them but I havent researched it, I have several friends running P heads that use 90 degree boots and say they work, its hard to see how though.
  10. maverick75
    accel makes shortie spark plugs. Theyve been doing it for years. If you do a search you can find scotts thread on those heads. And it has pictures of how the plugs hit the actual headers. I would just save the headache and go with the nonP heads. They flow just fine.
  11. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    I was born with a Mexican bottom end :biglaugh:
  12. Fro
    Fro Member
    Joplin Mo.
    I run the straight GT40 head and they are great, mine are unported with only good springs, the car runs low 12's on tires and gets over 20 mpg and I've only got 400$ in them so I agree with you, I didnt know that about the short plugs I'll have to check that out.
  13. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    We have windsor sr. heads on our mav. have to use accel short plugs and 90 degree boots turned up to keep from burning them up.
